| Infrarotsteuerung Kategorie: Pro-Bot128 (von PepeV - 16.10.2010 10:24) | ||
| Hi all, For only 3 Euros I bought a simple IR remote control in a department store. With it I made a remote control for the robot and a wealth of possibilities opened for me. The IR sensor of the robot is so sensitive that the robot can be controlled over a distance of at least 7 meters from any (!) direction. I think this is a possibility every Pro-bot owner should have. Though the solution is quite simple, it cost me a lot of time to realize it and therefore I want to share what I made. The RC transmitter I bought is programmable. With help of the manual and a lot of trial and error I found a setting that uses the required RC-5 Philips protocol. The transmitter has 6 buttons and a switch for TV or Satellite control. So 12 commands should be possible. In practice, there were only 11. There is an example of an IR receiver in the collection C-Control Pro Demos. However this approach is not suitable for the robot because it takes to much processor time. Every time RC5_Read() is called in the loop, 130 ms is used, even when there is no IR signal. It is much more efficient to call RC5_Read() only after an interrupt that is triggered by the IR-sensor at the beginning of a signal. I used the following program. #define TSOP 26 byte NewCommand; word KeyCode, RC_Code, OldRC_Code, DeviceCode; void main(void) { RC_Init(); NewCommand = false; RC_Code = 0; while (true) { if (RC_Code!=0) { KeyCode = RC_Code & 0b000000111111; // Extract bits 1 t/m 6 DeviceCode = (RC_Code & 0b011111000000) >> 6; // Extract bits 7 t/m 11 and shift right by 6 positions // The toggle bit (bit 12) is inverted when the same key is pushed // again, not if the key is held and automatic repetition occurs. // Thus it is possible to distinguish between those two kinds of // repetition. if (OldRC_Code != RC_Code) { NewCommand = true; OldRC_Code = RC_Code; } else NewCommand = false; RC_Code=0; Process_RC_Code(KeyCode, DeviceCode, NewCommand); } } } void RC_Init(void) { RC5_Init(TSOP); Ext_IntEnable(2,2); // TSOP is active low so falling edge trigger Irq_SetVect(INT_2, TSOP_ISR); // TSOP is connected to port 26 = interrupt 2 } void TSOP_ISR(void) { int irqcnt; RC_Code = RC5_Read(); irqcnt = Irq_GetCount(INT_2); //Interrupt Request Counter = 0 } void Process_RC_Code(byte aKeyCode, byte aDeviceCode, byte aNewCommand) { if (aDeviceCode == 0) // TV { switch (aKeyCode) { case 12: // Start/Stop if (aNewCommand) { // Place your commands here } else { // Place your commands here } break; case 32: // Prog+ if (aNewCommand) { // Place your commands here } else { // Place your commands here } break; // Etcetera for other keycodes like 17 (Vol-), 16 (Vol+), 33 (Prog-), 13 (Mute) } } else { if (aDeviceCode == 8) // SAT { switch (aKeyCode) { case 12: // Start/Stop if (aNewCommand) { // Place your commands here } else { // Place your commands here } break; // Etcetera for other keycodes } } } } Regards, Pepe | ||
| Antwort schreiben Antworten:  Re: Infrarotsteuerung (von ulrich korth - 18.10.2010 9:36)  Re: Infrarotsteuerung (von Ondra - 16.01.2011 19:02)  Re: Infrarotsteuerung (von PepeV - 18.01.2011 16:05) | ||
