| Re: ADC in Free Running Mode Kategorie: Programmierung C (von Torsten - 9.02.2013 10:18) | ||
| Als Antwort auf Re: ADC in Free Running Mode von PepeV - 8.02.2013 17:43 | ||
> > Hi Torsten, > > I managed to adapt your ADCaptureRunFree to work with a float array. > Since I could not find a suitable algorithm on the internet, I figured out > one myself. Because I need only to convert integers between 0 and 1023, > it is much simpler then the algorithms I found on internet. > I attached the results. Hope you like my first attempt of asm programming. > > Thanks for the asm spectrum analyzer files. They look promising (fast!) but > also complicated. I will study them and let you know if I can use them. > > Regards, > Pepe Hello Pepe, maybe the version below is still interesting for you. GruÃ? Torsten ADCapture-0.04.zip | ||
