| Re: Bitfolge am Port ausgeben Kategorie: Programmierung Basic (von Torsten - 16.09.2013 20:57) | ||
| Als Antwort auf Re: Bitfolge am Port ausgeben von Torsten - 13.09.2013 18:48 | ||
| > > > > That's the best I can do. > > I wonder if Paul is still interested and on line... > > > > Regards, > > Pepe > > Hallo Pepe, > > it looks like Paul is faded away. > The problem is, however, very interesting. > If it still interests you, then test the two versions. > "BitSequence-0.02" works with Timer1 and PortC5. > Hello everybody, I experimented still a little with the problem. Maybe the result interests somebody. "BitSequence-0.03" compares three versions. 1. BitSequenceSimple: without timers 2. BitSequenceTimer: using the so-called "Interpreter-Timer-Interrupts" 3. BitSequenceAsm: jumps into an assembler-call To give the so-called "Timer-Interrupts" a real chance, I tested it with a 500µs interval. The winner is of course the "BitSequenceAsm-version". For my astonishment, the "BitSequenceSimple-version" is more stable than the "BitSequenceTimer-version". That also shows the limits of the so-called "Interpreter-Interrupts". In addition the "BitSequenceTimer-version", works first no more correctly, if we reduce the interval time. Finally I come to the opinion, only the "BitSequenceAsm-version" is suitable for implementation of a asynchronous serial communication protocol. Gru� Torsten BitSequence-0.03.zip BitSequencePicture.zip | ||
| Antwort schreiben Antworten:  Re: Bitfolge am Port ausgeben (von PepeV - 17.09.2013 20:38)  Re: Bitfolge am Port ausgeben (von PepeV - 18.09.2013 22:12)  Re: Bitfolge am Port ausgeben (von Torsten - 21.09.2013 9:26) | ||
