Re: conversie word to hex Kategorie: IDE (von Tobias - 5.02.2017 23:35)
Als Antwort auf Re: conversie word to hex von Tobias - 5.02.2017 23:23
There is a silly thing with the forum-editor! When a write a backslash, the
editor don't show it! In the line:
Str_Printf(str, "%04xr", cnt1);
is a backslash missing after copy. Please insert a backslash in this line between
"%04x" and "r".
> Dear Bram,
> please try this. I hope it's what you needed. Otherwise I didn't understood you correctly.
> I only included the transformation from decimal value in a hex-formatted string and send it
> over the serial interface.
> I didn't checked any other things at your code!
> Regards, Tobias
> name:           - Inertia Dyno Power. Timer Moduul basis Timer0.
> input:          - Wheel sensor
> output:         - Timer Counts Seriel (prefer dec or hex) to the PC for Delphi interface
> description:    - Timer0 Interrupt, if timer has expired
> Mega32:  Output PD7 (PortD.7) for Test
> #ifdef MEGA32
> #define PORT_PWM 31
> #endif
> #define EXTINT 2
> #define INTMODE 2
> #define LF 0x0A
> #define CR 0x0D
> #define SPACE 0x20
> word cnt1;
> byte busy;
> char str[6];
> input:          - Sensor
> output:         - Timer Counts Seriel (dec or hex) to PC for Grafics (Delphi)
> void Ext_ISR(void)
> int irqcnt;
>    Timer_T0Stop();                 // Timer 0 Stop
> //    cnt1  = value timer pulses in word ?
> // ?  Str_Printf(str, "arg1: %dr", 1234);
> // ?  Str_Printf '=(%[width]x -> Hex-number)
> //    and send it then with
> // ?  Serial_WriteText(0,str);
> // ?  Serial_Write(0,cnt1);
>     Str_Printf(str, "%04xr", cnt1);  //Transform word to 4 digit hex (e.g. 65535 to FFFF)
>                                       //The "r" is a CR directly in the string
>     Serial_WriteText(0,str);          //Send the string to the serial interface
> //    Serial_Write(0,CR);            //It's in the string includes, see above!  // Send CR to PC forr Deplhi grafics interface
>     cnt1=0;                          // Set counter value 0
>     Ext_IntDisable(EXTINT);          // Disable Ext Interupt
>     Timer_T0FRQ(4,PS0_1024);         // Start Timer again
>     Ext_IntEnable(EXTINT,INTMODE);   // Ext Interupt enable
>     irqcnt=Irq_GetCount(INT_2);      // activeer interupt INT_2 from wheel speed
> void Timer0_ISR(void)
> int irqcnt;
> busy=0;
> irqcnt=Irq_GetCount(INT_TIM0COMP);      // Interrupt Request Counter
> void main(void)
>     Serial_Init(0,SR_8BIT|SR_1STOP|SR_NO_PAR,SR_BD9600);
>     Port_DataDirBit(PORT_PWM,PORT_OUT);     // Set port direction to output
>     Irq_SetVect(INT_TIM0COMP,Timer0_ISR);   // Define Interrupt
>     Irq_SetVect(INT_2,Ext_ISR);             // From (wheel) sensor to pin nr.10
>     while (1)
>         Timer_T0Time(4,PS0_1024);         // Ca. 1 ms need more adjusting
>         Port_WriteBit(PORT_PWM,0);        // Set port to control output to 0
>         busy=1;
>         while (busy);
>         Port_WriteBit(PORT_PWM,1);        // Set port to control output to 1
>         busy=1;
>         while (busy);
>         cnt1++;                           // Added Timer Pulses
>         Ext_IntEnable(EXTINT,INTMODE);    // Enable Ext. Interupt
> // EOF
