Re: ADC in Free Running Mode Kategorie: Programmierung C (von PepeV - 21.01.2013 20:13) | ||
Als Antwort auf Re: ADC in Free Running Mode von Torsten - 20.01.2013 11:26 | ||
> Hallo Pepe, > > you did not write into the ADCSRA-Register (0x06) > but into the Input-Capture-Register 1 (0x26). > Where came the address (0x26) from? I don't know. When > using the function "DirAcc_Write(...)" mistakes can > be made quickly. If you want to learn your robot, listen > to you, then the code below could be helpful. > > GruÃ? Torsten Hi Torsten, Thanks for your help. I took a brief look at the programs you sent and I am sure they are very instructive. But I need some (probably lots of) time to study them, since I have never done any programming in assembler. I will come back on it but that will take a while. Regards, Pepe | ||
