Re: ADC in Free Running Mode Kategorie: Programmierung C (von Torsten - 9.02.2013 10:18)
Als Antwort auf Re: ADC in Free Running Mode von PepeV - 8.02.2013 17:43
> Hi Torsten,
> I managed to adapt your ADCaptureRunFree to work with a float array.
> Since I could not find a suitable algorithm on the internet, I figured out
> one myself. Because I need only to convert integers between 0 and 1023,
> it is much simpler then the algorithms I found on internet.
> I attached the results. Hope you like my first attempt of asm programming.
> Thanks for the asm spectrum analyzer files. They look promising (fast!) but
> also complicated. I will study them and let you know if I can use them.
> Regards,
> Pepe
 Hello Pepe,
 maybe the version below is still interesting for you.
 GruÃ? Torsten
ADCapture-0.04.zip
Re: ADC in Free Running Mode (von PepeV - 9.02.2013 14:57)
    Re: ADC in Free Running Mode (von PepeV - 11.02.2013 18:29)
        Re: ADC in Free Running Mode (von Torsten - 11.02.2013 21:07)
            Re: ADC in Free Running Mode (von PepeV - 12.02.2013 19:54)
