Re: ADC in Free Running Mode Kategorie: Programmierung C (von PepeV - 11.02.2013 18:29) | ||
Als Antwort auf Re: ADC in Free Running Mode von PepeV - 9.02.2013 14:57 | ||
> > Hello Pepe, > > > > maybe the version below is still interesting for you. > > > > GruÃ? Torsten > > Hi Torsten, > > Thanks, I will look at it later. > Here is an improved version of my ADCapture2fl.asm. The previous version > has a serious bug. If an ADC value is zero, it will hang. That case is dealt > with now and also the code is optimized so less instructions are needed. > > Maybe we should start a new thread in the category Programmierung > Assembler. 'FFT for the Atmega128'? > > Regards, > Pepe Hi Torsten, Your version of the conversion of integer to float is better, more compact and elegant. Thanks! I learned a lot from it and was able to combine it with my version to obtain an even more compact code. See attachment. Regards, Pepe ADCapture2fl03.zip | ||
Antwort schreiben Antworten: Re: ADC in Free Running Mode (von Torsten - 11.02.2013 21:07) Re: ADC in Free Running Mode (von PepeV - 12.02.2013 19:54) |
