Re: Access to flash array Kategorie: Programmierung Assembler (von PeterS - 16.02.2013 17:20) | |
Als Antwort auf Access to flash array von PepeV - 16.02.2013 13:43
> Hi Peter, > > Is there a way to access (predefined) flash arrays in an assembler routine? > Or is the only option to copy the data to an array in RAM? > > Regards, > Pepe There is no implemented way to send the 24-bit flash address to the assembler subroutine. When accessing flash arrays there are special opcodes to copy bytes from flash to memory. Regards, Peter | |
Antwort schreiben Antworten: Re: Access to flash array (von PepeV - 17.02.2013 21:27) Re: Access to flash array (von PeterS - 18.02.2013 17:06) Re: Access to flash array (von Torsten - 18.02.2013 20:48) |
