Re: Access to flash array Kategorie: Programmierung Assembler (von PepeV - 17.02.2013 21:27) | ||
Als Antwort auf Re: Access to flash array von PeterS - 16.02.2013 17:20 | ||
> > Hi Peter, > > > > Is there a way to access (predefined) flash arrays in an assembler routine? > > Or is the only option to copy the data to an array in RAM? > > > > Regards, > > Pepe > > There is no implemented way to send the 24-bit flash address to the assembler > subroutine. When accessing flash arrays there are special opcodes to copy > bytes from flash to memory. > > Regards, > > Peter Too bad, but thanks! Are you considering to implement this feature in a future release? Regards, Pepe | ||
Antwort schreiben Antworten: Re: Access to flash array (von PeterS - 18.02.2013 17:06) Re: Access to flash array (von Torsten - 18.02.2013 20:48) |
