Re: Error in IntFunc_Lib.cc Kategorie: IDE (von PepeV - 9.02.2010 19:46)
Als Antwort auf Re: Error in IntFunc_Lib.cc von PeterS - 9.02.2010 9:07
> > The file IntFunc_Lib.cc contains two errors:
> > The blocks:
> > #ifdef MEGA32
> > #define PS0_1      1
> > #define PS0_8      2
> > #define PS0_64     3
> > #define PS0_256    4
> > #define PS0_1024   5
> > #endif // MEGA32
> > and
> > #ifdef MEGA128
> > #define PS0_1      1
> > #define PS0_8      2
> > #define PS0_32     3
> > #define PS0_64     4
> > #define PS0_128    5
> > #define PS0_256    6
> > #define PS0_1024   7
> > #endif // MEGA128
> > do not compile correctly because of the comments // MEGA32  resp. // MEGA128 in the last lines.
> > The result is that the MEGA128 uses the MEGA32 definitions which leads to unexpected results that
> > are very hard to debug as I noticed.
> That is not true. I tested it and it worked correctly. Should there be an exceptional case that
> leads to problems, please post it here or send it to ccpro@gmx.de.
> Regards
> Peter
Hi Peter,
Well, I don't know how you tested it but when I open the file IntFunc_Lib.cc in the IDE, the blocks
mentioned above are not marked with a line in the left margin as they should be. That is a clear
sign that that something is wrong I should say.
Besides, I noticed that definitions with #define also are not compiled when the command is
followed by a comment (//) on the same line.
Regards,
Pepe
Re: Error in IntFunc_Lib.cc (von PeterS - 10.02.2010 0:38)
    Re: Error in IntFunc_Lib.cc (von PepeV - 12.02.2010 11:26)
