Re: Timer_T1Time and Timer_T3Time do not work as they should Kategorie: IDE (von Conny - 10.04.2010 15:52)
Als Antwort auf Timer_T1Time and Timer_T3Time do not work as they should von PepeV - 19.02.2010 17:46
Hi,
after some hours of trail and error, I can Confirm this behaviour. Parameter time has no effect at all.
Bad, because I need it to set an exact  Intervall.
Does nobody know, why this is not working and/or a Workaroung/patch ???
Thanks
Conny
> Hi all (and especially Peter),
> The functions Timer_T1Time(word Time,byte PS) and Timer_T3Time(word Time,byte PS) generate
> interrupts with a frequency that does not match the parameters PS and Time. It seems that the value
> of Time is totally irrelevant and that the value of PS sets the prescaler values of the Mega32 while
> I compile for Mega128.
> In contrast, the function Timer_T0Time(byte Time,byte PS) does what should do for all values of PS and
> Time.
> Below is the program I used to test it and the results.
> Is this an error in the Mega128 or what?
> Regards,
> Pepe
> word T0_Cnt, T1_Cnt, T2_Cnt, T3_Cnt;
> void main(void)
>     Irq_SetVect(INT_TIM0COMP,T0_ISR);
>     Irq_SetVect(INT_TIM1CMPA,T1_ISR);
>     Irq_SetVect(INT_TIM2COMP,T2_ISR);
>     Irq_SetVect(INT_TIM3CMPA,T3_ISR);
>     Timer_T0Time(144,PS0_256);   // 400 Hz
>     Timer_T1Time(12345,PS0_32);  // Only the prescaler value matters. Why?!
>     // Timer T2 freq is allways 100 Hz
>     Timer_T3Time(54321,PS0_64);  // Only the prescaler value matters. Why?!
>     while (T2_Cnt<10000);   // run 100 sec
>     Msg_WriteFloat(T0_Cnt/100.0);
>     Msg_WriteChar(13);
>     Msg_WriteFloat(T1_Cnt/100.0);
>     Msg_WriteChar(13);
>     Msg_WriteFloat(T2_Cnt/100.0);
>     Msg_WriteChar(13);
>     Msg_WriteFloat(T3_Cnt/100.0);
>     Msg_WriteChar(13);
> void T0_ISR(void)
>     int irqcnt;
>     T0_Cnt++;
>     irqcnt=Irq_GetCount(INT_TIM0COMP);
> void T1_ISR(void)
>     int irqcnt;
>     T1_Cnt++;
>     irqcnt=Irq_GetCount(INT_TIM1CMPA);
> void T2_ISR(void)
>     int irqcnt;
>     T2_Cnt++;
>     irqcnt=Irq_GetCount(INT_TIM2COMP);
> void T3_ISR(void)
>     int irqcnt;
>     T3_Cnt++;
>     irqcnt=Irq_GetCount(INT_TIM3CMPA);
> The results:
> Timer_T1Time(xxxxx,PS0_1)      f=225,01 Hz   (matches Timer=65535 and PS=1)
> Timer_T1Time(xxxxx,PS0_8)      f= 28,12 Hz    (matches Timer=65535 and PS=8)
> Timer_T1Time(xxxxx,PS0_32)    f=  3,51 Hz     (matches Timer=65535 and PS=64)
> Timer_T1Time(xxxxx,PS0_64)    f=  0,88 Hz     (matches Timer=65535 and PS=256)
> Timer_T1Time(xxxxx,PS0_128)   f=  0,21 Hz    (matches Timer=65535 and PS=1024)
