Re: transfer Kategorie: IDE (von PeterS - 29.09.2010 19:48) | |
Als Antwort auf transfer von paul - 28.09.2010 23:16
> I have a problem with transfer a program to the c-control pro > When we connect the c-control direct with a rs232 cable to the computer > it works fine. Now we have make a datalogger with the c-control whats > transfer wireless data to a computer with a wireless rs232 connection (a xbee) > This works also fine. > But when i try to update my program in the c-control with the same connection it don't works. > I think the baudrate between the c-control and the ide is 38400 baud ? > When i try this and test it in the 'ide options menu' it said hardware found and also i can read the > hardware version. > Now if i try to transfer the program, it dont work. In the bar under at the screen i see a counter > that counts till 10 and then it's over. > > Anybody some idee whats the problem? Maybe the wireless connection is to slow with answering > that the ide dont see the c-control? > > Thanks for answering. > > Paul Hello Paul, there is a timeout of 1000ms for a 256 byte packet. When your wireless connection is too slow ( <4800baud ) it may come to such a problem. Also, I have fixed in the beta update a small problem that could lead to problems in rare cases. Perhaps you give the beta version a try. Best Regards, Peter | |
