Re: Voltcraft USB programmer cable Win 7 64 bit driver install Kategorie: Pro-Bot128 (von PepeV - 19.12.2011 12:52) | ||
Als Antwort auf Re: Voltcraft USB programmer cable Win 7 64 bit driver install von UlliS - 19.12.2011 9:27 | ||
> Hello Pepe, > > the V 1.0 Programmer (see CD Lable) works only with 32-bit Systems (Vista & Win7). > The new version V 2.0 works mith 64-bit. > The old programmer V 1.0, you need to reprogram the factory settings. > Then you can use the original driver. > > http://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx > > See AN144 and use the CP210xSetIDs.exe to reprogram. > > VID, PID and divece string see attachemend.. > > Best regards, > > Ulli > Hi Ulli, OK, this sounds a lot more convenient than my procedure. But before I try it I have this question: If I reprogram my V.1 programmer cable, will I still be able to use it with my other computer which runs on XP (32 bit)? And if so, wil I have to reinstall the driver there? Regards, Pepe | ||
