| Re: Voltcraft USB programmer cable Win 7 64 bit driver install Kategorie: Pro-Bot128 (von UlliS - 19.12.2011 17:18) | |
Als Antwort auf Re: Voltcraft USB programmer cable Win 7 64 bit driver install von PepeV - 19.12.2011 12:52
> > Hello Pepe, > > > > the V 1.0 Programmer (see CD Lable) works only with 32-bit Systems (Vista & Win7). > > The new version V 2.0 works mith 64-bit. > > The old programmer V 1.0, you need to reprogram the factory settings. > > Then you can use the original driver. > > > > http://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx > > > > See AN144 and use the CP210xSetIDs.exe to reprogram. > > > > VID, PID and divece string see attachemend.. > > > > Best regards, > > > > Ulli > > > > Hi Ulli, > > OK, this sounds a lot more convenient than my procedure. But before I try it I have this question: > If I reprogram my V.1 programmer cable, will I still be able to use it with my other computer which > runs on XP (32 bit)? And if so, wil I have to reinstall the driver there? > > Regards, > Pepe Youneed the new Silabs driver, works Xp up! Ulli | |
