| Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt Kategorie: Programmierung C (von Torsten - 23.04.2012 19:54) | ||
| Als Antwort auf Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt von PepeV - 22.04.2012 16:02 | ||
> Hi Torsten, > > I would not know how one could realize the solution you suggest: "der Input-Capture Interrupt den > Overflow-Interrupt-Zähler umschaltet". But have you already considered another, rather pragmatic > solution? One could use another timer to make a rough estimation of the period time and use that > value together with the value of the Input Capture Register to calculate an accurate value of the > period time. > > Period time measurement with prescaler PS_1 has a range of 65536 * 67.8 ns = 4.44 ms. > Therefore the period time equals the value of the Input Capture Register + n * 4.44 ms. If one sets > up another timer to increase a variable say every 1 ms, one could use its value in the PM IRQ > function to determine the value of n. > > As said, a pragmatic solution, not elegant and not absolutely fail safe. Maybe you discarded it > already. I think it will work in a simple program but probably not in a complex program that > consumes processor time in chunks of more than 1 ms. > > Regards, > Pepe Hi Pepe, do you have an code-example for your suggestion? The first timer runs in normal mode. So he is not reset at an input-capture event. The second timer does not know anything about the first timer. At the moment i would not know any solution there. The accuracy of the time measurement is only restricted by the system clock. The C control user becomes not this possibility for longer time measurements. An important condition would be the possibility to be able to write assembler interrupt functions. Regards Torsten | ||
