| Re: FFT routines Kategorie: Programmierung Assembler (von PepeV - 19.03.2013 13:47) | ||
| Als Antwort auf Re: FFT routines von Torsten - 28.02.2013 19:51 | ||
| > Hello Pepe, > > to prevent that valuable RAM-memory is consumed, > I can suggest two solutions to you. > > -writing asm-code that functioned as a array > > -using the EEPROM > > We can not write such code by ourselves, > but we can make, however, like ChanN did. > Let's make perl for us write the code. > See below. Hi Torsten, Beautifully done! But I don't think I will use your solutions because I need only 128 samples and have enough RAM space for that. Right now processor time is more valuable than RAM and I suspect that both methods you worked out add substantially to the total time (though I didn't really test it because I cannot compile perl code). P.S. Sorry to response so late but for unknown reasons the forum did not except my postings for a long time. Regards, Pepe | ||
