| Re: neue IDE Kategorie: IDE (von ThomasJ - 27.09.2013 15:36) | |
Als Antwort auf Re: neue IDE von PeterS - 26.09.2013 14:34
> > > > > > > Hi Peter, > > > > > > > > > > > > > > I noticed you swapped the values of the port definitions PORT_ON and PORT_OFF > > > > > > > in IntFunc_Lib.cc. That can have huge consequences for existing programs. I did not > > > > > > > see any warnings for this change; did I overlook something? > > > > > > > > > > > > I checked it, I made the correction internally mid 2011. The old definition was > > > > > > definitely wrong. But you maybe right, perhaps some people used PORT_ON, PORT_OFF > > > > > > the wrong way, and now programs may fail. I will add a warning. > > > > > > > > > > I have put a new build 2.31.0.89 with some added warnings online. > > > > > > > > > > > > > > > > > Regards, > > > > > > > > > > > > Peter > > > > > > > > > > > > > > > > > > > > Regards, > > > > > > > Pepe > > > > > > > > > > > > > > Hi Peter, > > > > > > > > It is good that you added the warnings. I hope it is enough because the new > > > > definitions of PORT_ON and PORT_OFF will be an issue for all Pro-Bot 128 users. > > > > The library PRO-BOT128_Lib.cbas makes extensive use of PORT_ON and > > > > PORT_OFF. > > > > The old definitions PORT_ON 0 and PORT_OFF 1 where not illogical for > > > > Pro-Bot 128 users because the circuit design is such that a value of 1 at a port > > > > causes a led to switch off and vice versa. I think Pro-Bot 128 users are often > > > > beginners so many will not understand what is happening when the run their > > > > programs from the new IDE. I would therefore like to issue this > > > > > > > > WARNING FOR ALL PRO-BOT 128 USERS: to work with this new > > > > IDE 2.31, the library PRO-BOT128_Lib.cbas should be adapted. All occurences of > > > > PORT_ON should be replaced by PORT_OFF and all occurences of PORT_OFF > > > > should be replaced PORT_ON. > > > > > > > > Regards, > > > > Pepe > > > > > > Hello Pepe, > > > > > > I will talk to the author of the ProBot Library on Monday. There will > > > be an update soon. > > > > > > Best Regards, > > > > > > Peter > > > > Hallo Peter, > > > > nur eine kleiner bug in der neuen IDE. > > Unter XP lässt sich im Hilfemenü der Text nicht nach unten scrollen. > > > > GrüÃ?e > > Thomas > > Hallo Thomas, > > ich kann mir das noch nicht vorstellen, welcher Text? Die Menüeinträge? > Hast Du vielleicht mal einen Screenshot für mich? > > Gruss Peter Hallo Peter, anbei der screenshot Gruss Thomas screenshot.png: ![]() | |
