Re: neue IDE Kategorie: IDE (von Sepp - 27.09.2013 18:57)
Als Antwort auf Re: neue IDE von ThomasJ - 27.09.2013 15:36
> > > > > > > > Hi Peter,
> > > > > > > > I noticed you swapped the values of the port definitions PORT_ON and PORT_OFF
> > > > > > > > in IntFunc_Lib.cc. That can have huge consequences for existing programs. I did not
> > > > > > > > see any warnings for this change; did I overlook something?
> > > > > > > I checked it, I made the correction internally mid 2011. The old definition was
> > > > > > > definitely wrong. But you maybe right, perhaps some people used PORT_ON, PORT_OFF
> > > > > > > the wrong way, and now programs may fail. I will add a warning.
> > > > > > I have put a new build 2.31.0.89 with some added warnings online.
> > > > > > > Regards,
> > > > > > > Peter
> > > > > > > > Regards,
> > > > > > > > Pepe
> > > > > Hi Peter,
> > > > > It is good that you added the warnings. I hope it is enough because the new
> > > > > definitions of PORT_ON and PORT_OFF will be an issue for all Pro-Bot 128 users.
> > > > > The library PRO-BOT128_Lib.cbas makes extensive use of PORT_ON and
> > > > > PORT_OFF.
> > > > > The old definitions PORT_ON 0 and PORT_OFF 1 where not illogical for
> > > > > Pro-Bot 128 users because the circuit design is such that a value of 1 at a port
> > > > > causes a led to switch off and vice versa. I think Pro-Bot 128 users are often
> > > > > beginners so many will not understand what is happening when the run their
> > > > > programs from the new IDE. I would therefore like to issue this
> > > > > WARNING FOR ALL PRO-BOT 128 USERS: to work with this new
> > > > > IDE 2.31, the library PRO-BOT128_Lib.cbas should be adapted. All occurences of
> > > > > PORT_ON should be replaced by PORT_OFF and all occurences of PORT_OFF
> > > > > should be replaced PORT_ON.
> > > > > Regards,
> > > > > Pepe
> > > > Hello Pepe,
> > > > I will talk to the author of the ProBot Library on Monday. There will
> > > > be an update soon.
> > > > Best Regards,
> > > > Peter
> > > Hallo Peter,
> > > nur eine kleiner bug in der neuen IDE.
> > > Unter XP lässt sich im Hilfemenü der Text nicht nach unten scrollen.
> > > Grü�e
> > > Thomas
> > Hallo Thomas,
> > ich kann mir das noch nicht vorstellen, welcher Text? Die Menüeinträge?
> > Hast Du vielleicht mal einen Screenshot für mich?
> > Gruss Peter
> Hallo Peter,
> anbei der screenshot
> Gruss Thomas
ich nutze auch Windows XP (Vers 5.1 Service Pack3) und bei mir funktioniert das ganz normal.
Aber mir ist aufgefallen dass die Demoprogramme in Englisch kommentiert sind, kommt das evtl. noch in Deutsch?
Bei uns älteren ist dass mit dem Englisch halt teilweise nicht ganz so einfach....
Aber scheint mir sehr interesant zu sein diese neue C-Control AVR 32Bit.
Viele Grüsse
 Sepp
Re: neue IDE (von PeterS - 28.09.2013 8:11)
    Re: neue IDE (von Sepp - 29.09.2013 11:42)
