Re: compilation error Kategorie: Pro-Bot128 (von UlliS - 24.03.2016 8:53)
Als Antwort auf Re: compilation error von Alan - 23.03.2016 16:22
C-Control Pro Mega32, C-Control Pro Mega128, CC-Pro 32 Application Board, CC-Pro 128 Application Board, Pro-Bot128, C-Control Pro AVR32, eigenes Board
> > > > > > Hello,
> > > > > > Who can help me? I've started to programme my PRO BOT and when i push "transfer program" i haven't recived
> > > > > > a succes message. Is it normal? And, when i push "start programme" i recived the message:" global variables RAM
> > > > > > access failure at adress 49977" And the pro bot doesn't work. What i must do?
> > > > > > thank you!!!
> > > > > Hi,
> > > > > which version of the IDE you use?
> > > > Hi,
> > > > I use the 2.12.0.10 version
> > >  I have another program version the 2.31.0.39 but i have the same Problem
> > test "reset Modul" in the IDE and upload new.
> Now, I recived the message (when i push start program) "No interpreter loaded". What i must do? thank for your time
Do upload a Programm (Boot Mode) and make a Module reset.
And Try again...
Re: compilation error (von Alan - 24.03.2016 9:41)
