| Re: compilation error Kategorie: Pro-Bot128 (von Alan - 24.03.2016 9:41) | ||
| Als Antwort auf Re: compilation error von UlliS - 24.03.2016 8:53 | ||
> > > > > > > Hello, > > > > > > > Who can help me? I've started to programme my PRO BOT and when i push "transfer program" i haven't recived > > > > > > > a succes message. Is it normal? And, when i push "start programme" i recived the message:" global variables RAM > > > > > > > access failure at adress 49977" And the pro bot doesn't work. What i must do? > > > > > > > thank you!!! > > > > > > > > > > > > Hi, > > > > > > > > > > > > which version of the IDE you use? > > > > > > > > > > > > > > > Hi, > > > > > I use the 2.12.0.10 version > > > > I have another program version the 2.31.0.39 but i have the same Problem > > > > > > test "reset Modul" in the IDE and upload new. > > > > > Now, I recived the message (when i push start program) "No interpreter loaded". What i must do? thank for your time > > > Do upload a Programm (Boot Mode) and make a Module reset. > And Try again... > What do you mean with Boot Mode? Where I can find it. Sorry, but i am new in this program...  | ||
