Programme not running Kategorie: Programmierung C (von Bram Vooys - 15.09.2017 13:28)
C-Control Pro Mega32
Programme  not running what did I do wrong?
Program: Dynamic Shock Absorber Test
Unit: C_Control PRO Mega 32
IDE:  C_Control PRO IDE
Function:
Reading  from a Rotary Encoder
Trig0 = 360 grd
Trig1 = 360/200
input:          Trig0,Trig1
input:          AD0,AD1,AD3
output:         DO1,DO2: Relais sturing
output:         D/A (later ?)
Input and Output is done via RS232 interface
// Declaratie Poorten Interupt ??
// ??  #define EXTINT 26  // Externe ingang pin nr PD2
// ??  #define INTMODE 3  // Rising Edge
// ??  #define EXTINT 27  // Externe ingang pin nr PD3
   #define LF 0x0A
   #define CR 0x0D
void Pulse0(int Trig0)
   //  Ext_IntDisable(26); ??
   //  Set Data Register for Start place (later)
     Serial_WriteText(0,"Trig0");              // Test
void Pulse1(int Trig1)
   //  Ext_IntDisable(27); ??
   //  Increment Data Register
   //  Store data (Register+1)from ADC
     Serial_WriteText(0,"Trig1");             // Test
void main(void)
    int Trig0;
    int Trig1;
    int  i;
    int  n;
    byte c;                                   // Variables declaration
    byte Buf_Index;
    word ADC_Value;
    char ADC_String[10];
    Serial_Init(0,SR_8BIT|SR_1STOP|SR_NO_PAR,SR_BD9600);
    ADC_Set(ADC_VREF_VCC,0);
    Irq_SetVect(INT_0,Trig0);
    Irq_SetVect(INT_1,Trig1);
    Ext_IntEnable(0,1);
    Ext_IntEnable(1,1);
    Port_DataDirBit(19,1);                     // Start Stop Freq Reg.
    Port_DataDirBit(20,1);                     // Res.
    while(1)
    c=Serial_ReadExt(0);
    if(c==65)             // A
    Port_WriteBit(19,PORT_ON);
    if(c==67)             // C
    Port_WriteBit(19,PORT_OFF);
//    Stop Interupt 1 en 2
//    Read Register from 0-200  (later)
   if(c==63)             // Only for test
    {for (i=0;i<3;i++)
      ADC_Set(0x40,i);
      Str_WriteInt(ADC_Read(),ADC_String,0);     // 0 RPM 0-5 Volt
      Serial_WriteText(0,ADC_String);            // 1 Force 0-5 Volt
      Serial_WriteText(0,":");                   // 2 Temp
      AbsDelay(5);
      Serial_Write(0,CR);
      Buf_Index=0;                               // Clear buffer
//   Set Interup on
Please help.
Thanks Bram
Re: Programme not running (von Tobias - 26.09.2017 20:44)
