| Programme not running Kategorie: Programmierung C (von Bram Vooys - 15.09.2017 13:28) | ||
| Programme  not running what did I do wrong? /*------------------------------------------------------ Program: Dynamic Shock Absorber Test Unit: C_Control PRO Mega 32 IDE: C_Control PRO IDE Function: Reading from a Rotary Encoder Trig0 = 360 grd Trig1 = 360/200 input: Trig0,Trig1 input: AD0,AD1,AD3 output: DO1,DO2: Relais sturing output: D/A (later ?) Input and Output is done via RS232 interface /*---------------------------------------------------*/ // Declaratie Poorten Interupt ?? // ?? #define EXTINT 26 // Externe ingang pin nr PD2 // ?? #define INTMODE 3 // Rising Edge // ?? #define EXTINT 27 // Externe ingang pin nr PD3 // ?? #define INTMODE 3 // Rising Edge #define LF 0x0A #define CR 0x0D /*----------------------------------------------------*/ void Pulse0(int Trig0) { // Ext_IntDisable(26); ?? // Set Data Register for Start place (later) Serial_WriteText(0,"Trig0"); // Test } void Pulse1(int Trig1) { // Ext_IntDisable(27); ?? // Increment Data Register // Store data (Register+1)from ADC Serial_WriteText(0,"Trig1"); // Test } void main(void) { int Trig0; int Trig1; int i; int n; byte c; // Variables declaration byte Buf_Index; word ADC_Value; char ADC_String[10]; Serial_Init(0,SR_8BIT|SR_1STOP|SR_NO_PAR,SR_BD9600); ADC_Set(ADC_VREF_VCC,0); Irq_SetVect(INT_0,Trig0); Irq_SetVect(INT_1,Trig1); Ext_IntEnable(0,1); Ext_IntEnable(1,1); Port_DataDirBit(19,1); // Start Stop Freq Reg. Port_DataDirBit(20,1); // Res. while(1) { c=Serial_ReadExt(0); if(c==65) // A { Port_WriteBit(19,PORT_ON); } if(c==67) // C { Port_WriteBit(19,PORT_OFF); } // Stop Interupt 1 en 2 // Read Register from 0-200 (later) if(c==63) // Only for test {for (i=0;i<3;i++) { ADC_Set(0x40,i); Str_WriteInt(ADC_Read(),ADC_String,0); // 0 RPM 0-5 Volt Serial_WriteText(0,ADC_String); // 1 Force 0-5 Volt Serial_WriteText(0,":"); // 2 Temp AbsDelay(5); Serial_Write(0,CR); } Buf_Index=0; // Clear buffer } // Set Interup on } } Please help. Thanks Bram | ||
| Antwort schreiben Antworten:  Re: Programme  not running  (von Tobias - 26.09.2017 20:44) | ||
