Re: USB Programmer Treiber Update Kategorie: IDE (von PepeV - 24.12.2010 13:31)
Als Antwort auf Re: USB Programmer Treiber Update von PeterS - 23.12.2010 23:03
C-Control Pro Mega128, Pro-Bot128
> > > Vielleicht hilft es mal jemanden: Ich hatte das Problem, dass unter Windows 7 der USB Programmer zwar
> > > erkannt wurde und einen COM-Port bekam. Dieser COM-Port konnte dann in der IDE aber nicht ausgewählt
> > > werden. Bei mir hat es geholfen, den aktuellen Treiber direkt von der Silicon Labs Seite
> > > herunterzuladen (ist Version 6.20, die von Conrad ist 5.40).
> > > http://www.silabs.com/products/interface/usbtouart/Pages/usb-to-uart-bridge.aspx
> > > dann rechts unter "Design Tools|Software Downloads"
> > Hi,
> > I have tried many times with different drivers but nothing seems to work, also not the one you mention.
> > When I plug in the program cable for the first time, the COM port is correctly shown in the Device
> > Manager (CP210x USB to UART bridge (COM3)).
> > When I pull the cable out and than plug it in again, a yellow exclamation sign appears besides the
> > entry. When I check the properties of the COM port, it says that Windows cannot verify the digital
> > signature (etc.).
> > Is it because my Windows 7 is 64 bit?
> Yes, I think that is it. There are some descriptions in the net how to allow a uncertified
> driver to be installed in Win7 64Bit. Please give them a try.
> Regards,
> Peter
> > Is my cable too old (1 year)?
> > Anybody any idea?
> > Pepe
Well, I found and tried this: http://www.killertechtips.com/2009/05/05/disable-driver-signing-windows-7/
which puts Windows 7 permanently in test mode. It didn't help.
I was afraid I would be stuck in test mode forever but luckily I found a way to get Windows out of it here:
http://social.technet.microsoft.com/Forums/en-US/w7itprohardware/thread
/bf2ca4ca-073c-48c3-bad2-15f47776b759
I give up and will continue to use my old XP computer to program the Pro-bot.
Maybe some day Conrad Electronics will come up with a solution. They can't ignore the growing use
of Win 7 64bit forever, can they?
Pepe
