Switch between Timer_T3Time and Timer_T3PWM Kategorie: Programmierung C (von PepeV - 10.07.2011 21:08)
C-Control Pro Mega128, Pro-Bot128
Hi all,
I want to use timer3 in the same program first as interrupttimer with Timer_T3Time and then as source
for PWM with Timer_T3PWM. But I can't get this to work. When I call Timer_T3PWM after
Timer_T3Time, the program gets stuck. Calling Timer_T3Stop in between doesn't help either.
Does anyone know a solution to this problem?
(You may answer in German if you prefer.)
Regards,
Pepe
