| Re: Compiler Kategorie: IDE (von Alejandro - 8.02.2013 15:25) | ||
| Als Antwort auf Re: Compiler von PeterS - 7.02.2013 12:05 | ||
> > Hello, > > > > I am starting working with the Mega128. > > I am trying to compile one of the demos included in the CD. > > However the compilation doesn´t finish and I cannot start the program. > > This is what appears on the messages window: > > > > Compiling Project LED1 > > C-Control Pro Compiler (C) 2011 Conrad Electronic > > Running pass 1 > > Running pass 1 > > 2 bytes (4kb:0% - 64kb:0%) global Variables > > Generating Bytecode - 198 bytes.. > > Writing Symbols - 9126 bytes.. > > > > But it never completes the compilation. > > I have tried to change some options of the compiler but no way to solve it. > > Did anyone have the same problem or has an idea of how to solve it? > > > > Thanks in advance. > > > > The compiler is ready. When you see "Generating Bytecode" you can transfer the > program to the Unit and then start. > > Regards, > > > > Alejandro Thank you very much Peter. You are completely right. Actually, my problem was the USB conection, so the options to transfer the program were not available and that was what made me think that could be a problem with the compilation. Regards. | ||
