Re: Interrupt handling Kategorie: Programmierung Assembler (von Torsten - 31.03.2014 20:44)
Als Antwort auf Re: Interrupt handling von PeterS - 29.03.2014 14:06
> > > Would it be possible to replace that routine with another one, e.g.
> > > by changing the interrupt vector?
> > I would warn urgently against that unless you knows the system
> > very exactly. For polling the interrupt flag you need only few
> > system clocks.
> You are right, changing the interrupt vectors can have ugly side effects.
> But except the timer interrupt that is used for multitasking, servo and clock,
> experimenting with the other interrupts should not be fatal.
> Regards,
> Peter
Hallo Peter,
that would mean, Pepe's proposal is possible?
GruÃ? Torsten
Re: Interrupt handling (von PeterS - 3.04.2014 11:39)
    Re: Interrupt handling (von Torsten - 3.04.2014 20:39)
        Re: Interrupt handling (von PeterS - 13.04.2014 10:44)
        Re: Interrupt handling (von PepeV - 8.04.2014 17:31)
            Re: Interrupt handling (von Torsten - 8.04.2014 20:37)
                Re: Interrupt handling (von PepeV - 9.04.2014 20:14)
                    Re: Interrupt handling (von Torsten - 14.04.2014 20:10)
