Re: Interrupt handling Kategorie: Programmierung Assembler (von Torsten - 31.03.2014 20:44) | ||
Als Antwort auf Re: Interrupt handling von PeterS - 29.03.2014 14:06 | ||
> > > Would it be possible to replace that routine with another one, e.g. > > > by changing the interrupt vector? > > > > I would warn urgently against that unless you knows the system > > very exactly. For polling the interrupt flag you need only few > > system clocks. > > You are right, changing the interrupt vectors can have ugly side effects. > But except the timer interrupt that is used for multitasking, servo and clock, > experimenting with the other interrupts should not be fatal. > > Regards, > > Peter Hallo Peter, that would mean, Pepe's proposal is possible? GruÃ? Torsten | ||
Antwort schreiben Antworten: Re: Interrupt handling (von PeterS - 3.04.2014 11:39) Re: Interrupt handling (von Torsten - 3.04.2014 20:39) Re: Interrupt handling (von PeterS - 13.04.2014 10:44) Re: Interrupt handling (von PepeV - 8.04.2014 17:31) Re: Interrupt handling (von Torsten - 8.04.2014 20:37) Re: Interrupt handling (von PepeV - 9.04.2014 20:14) Re: Interrupt handling (von Torsten - 14.04.2014 20:10) |
