Re: ccpro_pcflcd.zip Kategorie: Programmierung C (von PepeV - 2.01.2015 14:56)
Als Antwort auf Re: ccpro_pcflcd.zip von Torsten - 27.12.2014 19:49
Pro-Bot128
> Hello Pepe,
> Many thanks for testing the program. The backlight- and cursorposition-
> problems should be solved. But the contrast-problem looks like a
> hardware problem.
> GruÃ? Torsten.
Hi Torsten,
There is a #endif missing at the end of Test5BackLight.cc.
The backlight seems to work well. When I switch on the device this is
what I see:
light on (default)
light off (5 s)
light on (5 s)
light off (5 s)
light on (5 s)
Text begins.
But the feedback in debug mode is not correct. I get:
backlightstate: 0000 : off ?
With the running text the contrast is bad. I agree with you that
this is a hardware problem. I have a 16x2 characters display
that apparently is not compatible with 1-line operation mode.
The rest works fine.
Best wishes for 2015.
Pepe
