Re: compilation error Kategorie: Pro-Bot128 (von Alan - 24.03.2016 9:41)
Als Antwort auf Re: compilation error von UlliS - 24.03.2016 8:53
> > > > > > > Hello,
> > > > > > > Who can help me? I've started to programme my PRO BOT and when i push "transfer program" i haven't recived
> > > > > > > a succes message. Is it normal? And, when i push "start programme" i recived the message:" global variables RAM
> > > > > > > access failure at adress 49977" And the pro bot doesn't work. What i must do?
> > > > > > > thank you!!!
> > > > > > Hi,
> > > > > > which version of the IDE you use?
> > > > > Hi,
> > > > > I use the 2.12.0.10 version
> > > >  I have another program version the 2.31.0.39 but i have the same Problem
> > > test "reset Modul" in the IDE and upload new.
> > Now, I recived the message (when i push start program) "No interpreter loaded". What i must do? thank for your time
> Do upload a Programm (Boot Mode) and make a Module reset.
> And Try again...
> What do you mean with Boot Mode? Where I can find it. Sorry, but i am new in this program...
