Re: neue IDE Kategorie: IDE (von PepeV - 22.09.2013 10:40)
Als Antwort auf Re: neue IDE von PeterS - 21.09.2013 12:47
> > > Hi Peter,
> > > I noticed you swapped the values of the port definitions PORT_ON and PORT_OFF
> > > in IntFunc_Lib.cc. That can have huge consequences for existing programs. I did not
> > > see any warnings for this change; did I overlook something?
> > I checked it, I made the correction internally mid 2011. The old definition was
> > definitely wrong. But you maybe right, perhaps some people used PORT_ON, PORT_OFF
> > the wrong way, and now programs may fail. I will add a warning.
> I have put a new build 2.31.0.89 with some added warnings online.
> > Regards,
> > Peter
> > > Regards,
> > > Pepe
Hi Peter,
It is good that you added the warnings. I hope it is enough because the new
definitions of PORT_ON and PORT_OFF will be an issue for all Pro-Bot 128 users.
The library PRO-BOT128_Lib.cbas makes extensive use of PORT_ON and
PORT_OFF.
The old definitions PORT_ON 0 and PORT_OFF 1 where not illogical for
Pro-Bot 128 users because the circuit design is such that a value of 1 at a port
causes a led to switch off and vice versa. I think Pro-Bot 128 users are often
beginners so many will not understand what is happening when the run their
programs from the new IDE. I would therefore like to issue this
WARNING FOR ALL PRO-BOT 128 USERS: to work with this new
IDE 2.31, the library PRO-BOT128_Lib.cbas should be adapted. All occurences of
PORT_ON should be replaced by PORT_OFF and all occurences of PORT_OFF
should be replaced PORT_ON.
Regards,
Pepe
Re: neue IDE (von PeterS - 22.09.2013 20:22)
    Re: neue IDE (von ThomasJ - 25.09.2013 9:18)
        Re: neue IDE (von PeterS - 26.09.2013 14:34)
            Re: neue IDE (von ThomasJ - 27.09.2013 15:36)
                Re: neue IDE (von PeterS - 28.09.2013 8:07)
                Re: neue IDE (von Sepp - 27.09.2013 18:57)
                    Re: neue IDE (von PeterS - 28.09.2013 8:11)
                       Re: neue IDE (von Sepp - 29.09.2013 11:42)
