Re: Error in IntFunc_Lib.cc Kategorie: IDE (von PepeV - 9.02.2010 19:46) | |
Als Antwort auf Re: Error in IntFunc_Lib.cc von PeterS - 9.02.2010 9:07
> > The file IntFunc_Lib.cc contains two errors: > > > > The blocks: > > > > #ifdef MEGA32 > > #define PS0_1 1 > > #define PS0_8 2 > > #define PS0_64 3 > > #define PS0_256 4 > > #define PS0_1024 5 > > #endif // MEGA32 > > > > and > > > > #ifdef MEGA128 > > #define PS0_1 1 > > #define PS0_8 2 > > #define PS0_32 3 > > #define PS0_64 4 > > #define PS0_128 5 > > #define PS0_256 6 > > #define PS0_1024 7 > > #endif // MEGA128 > > > > do not compile correctly because of the comments // MEGA32 resp. // MEGA128 in the last lines. > > The result is that the MEGA128 uses the MEGA32 definitions which leads to unexpected results that > > are very hard to debug as I noticed. > > That is not true. I tested it and it worked correctly. Should there be an exceptional case that > leads to problems, please post it here or send it to ccpro@gmx.de. > > Regards > > Peter Hi Peter, Well, I don't know how you tested it but when I open the file IntFunc_Lib.cc in the IDE, the blocks mentioned above are not marked with a line in the left margin as they should be. That is a clear sign that that something is wrong I should say. Besides, I noticed that definitions with #define also are not compiled when the command is followed by a comment (//) on the same line. Regards, Pepe | |
Antwort schreiben Antworten: Re: Error in IntFunc_Lib.cc (von PeterS - 10.02.2010 0:38) Re: Error in IntFunc_Lib.cc (von PepeV - 12.02.2010 11:26) |
