Re: Error in IntFunc_Lib.cc Kategorie: IDE (von PeterS - 10.02.2010 0:38) | |
Als Antwort auf Re: Error in IntFunc_Lib.cc von PepeV - 9.02.2010 19:46
> > > The file IntFunc_Lib.cc contains two errors: > > > > > > The blocks: > > > > > > #ifdef MEGA32 > > > #define PS0_1 1 > > > #define PS0_8 2 > > > #define PS0_64 3 > > > #define PS0_256 4 > > > #define PS0_1024 5 > > > #endif // MEGA32 > > > > > > and > > > > > > #ifdef MEGA128 > > > #define PS0_1 1 > > > #define PS0_8 2 > > > #define PS0_32 3 > > > #define PS0_64 4 > > > #define PS0_128 5 > > > #define PS0_256 6 > > > #define PS0_1024 7 > > > #endif // MEGA128 > > > > > > do not compile correctly because of the comments // MEGA32 resp. // MEGA128 in the last lines. > > > The result is that the MEGA128 uses the MEGA32 definitions which leads to unexpected results that > > > are very hard to debug as I noticed. > > > > That is not true. I tested it and it worked correctly. Should there be an exceptional case that > > leads to problems, please post it here or send it to ccpro@gmx.de. > > > > Regards > > > > Peter > > Hi Peter, > > Well, I don't know how you tested it but when I open the file IntFunc_Lib.cc in the IDE, the blocks > mentioned above are not marked with a line in the left margin as they should be. That is a clear > sign that that something is wrong I should say. That is a clear sign that the parser inside the editor is different than the preprocessor that is used for compiling. > Besides, I noticed that definitions with #define also are not compiled when the command is > followed by a comment (//) on the same line. Please show me, I get no error. The follwing example shows the correct results on a MEGA128: #define XYZZY "42r" // that is a comment void main(void) { int i; i= PS0_1024; Msg_WriteText(XYZZY); Msg_WriteInt(i); } Regards Peter > > Regards, > Pepe | |
