Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt Kategorie: Programmierung C (von Torsten - 24.04.2012 20:31)
Als Antwort auf Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt von PepeV - 24.04.2012 14:40
> Hi Torsten,
> The principle is as follows.
> Program a 1 ms counter and make sure it is set to zero it at the end of your function
> ICT3IrqCapture. When ICT3IrqCapture is called again, this ms counter would then give an
> approximate value of the period time (in ms). One could then use this value to calculate the
> number of overflows of the Input Capture Timer.
> Example.
> Suppose the difference between the current and the previous value of the Input Capture Register
> is 65289. Then the period time could be 4.427 ms or 8.870 ms or 13.314 ms etc.
> If the value of the ms counter is 8, I would know that 8,870 ms is the correct value. And even if
> the ms counter is one short (7) or one in excess (9), I still would know that 8,870 ms is the
> correct value.
> Outline of the program.
> Set up and run a millisecond timer and assign to it an IRQ function that increases a variable
> MST_Ticks every 1 ms. E.g. Timer_T0Time(230, PS0_64) would give ticks of 0,9983 ms.
> Define some time quantities (in ns):
> #define ICT_Tick_ns 6.782e1 // the length of a tick of the Input Capture Timer
> #define ICT_Range_ns 4.444e6 // the range of the Input Capture Timer (= 2^16 * ICT_Tick_ns)
> #define MST_Tick_ns 9.983e5 // the length of a tick of the millisecond timer
> Adapt your ICT3IrqCapture:
> ICT_Ticks = New_ICR_Value - Old_ICR_Value;
> ICT_Overflows = round((MST_Ticks*MST_Tick_ns - ICT_Ticks*ICT_Tick_ns) / ICT_Range_ns);
> PeriodTime = ICT_Overflows*ICT_Range_ns + ICT_Ticks*ICT_Tick_ns;
> MST_Ticks = 0;
> This should do the trick. Only in the case of very long period times (order of seconds) errors
> would arise caused by limited accuracy of real variables. In that case some optimization
> could probably be achieved by doing the calculations in ICT ticks instead of ns and using
> dwords instead of reals where possible. Also, when the program would cause delays that
> prevent handling the interrupts of the ms timer or the Input Capture Timer for more than 1 ms,
> errors would arise.
> If any questions remain, let me know.
> I could not test this program so I would be curious to know the results.
> Regards,
> Pepe
Hi Pepe,
estimate the overflows will make the same problem.
Between the input-capture event and the call of the
interrupt function passes by too much time.
The second timer will keep on running.
But is the second timer near the overrun border,
he is counting one too much.
This is supplying a wrong value occasionally.
It would be nice, we have more information about
the interrupt handling of the byte-code interpreter.
Unfortunately it seems to be a secret of the C-Control developer.
This turns the C-Control into a miracle bag.
Regards Torsten
Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von PepeV - 25.04.2012 13:27)
    Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von Torsten - 27.04.2012 20:41)
        Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von PepeV - 28.04.2012 16:05)
            Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von Torsten - 1.05.2012 8:18)
                Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von PepeV - 1.05.2012 21:48)
                    Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von Torsten - 2.05.2012 21:02)
                       Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von PepeV - 4.05.2012 15:15)
                          Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von Torsten - 5.05.2012 6:26)
                             Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von PepeV - 5.05.2012 14:45)
                                Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von Torsten - 6.05.2012 8:34)
                                   Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt (von PepeV - 7.05.2012 20:33)
