| Re: conversie word to hex Kategorie: IDE (von Tobias - 5.02.2017 18:36) | |
Als Antwort auf conversie word to hex von Bram Vooys - 4.02.2017 21:47
> > Frends, > > How can I convert cnt1 to a HEX mumber > > word cnt1; > Serial_Write(0,cnt1); // send to the host > > Thanks. Dear Bram, what you will send to the host exactly? In your example you will send a byte with the 'Serial_Write'-function. But then it's unimportant if you send it in binary-format (0b....), hex-format (0x....) or decimal-format. The result, what the Serial_Write-function send is always the same. For the different notations note in the manual "Variablen": c=5; // decimal-format a=0x3ff; // hex-format x=0b1001; // binary-format But if your host need really the HEX-format in ASCII-format, you must convert it with the 'Str_Printf'-function in a character (%[width]x -> Hex-number) and send it then with "Serial_WriteText"! (http://www.c-control-pro.de/documentation/index.html?str_printf.htm) I hope this information helps you. Otherwise you must send more information about your host, maybe a datasheet!? Regards, Tobias | |
