| Re: conversie word to hex Kategorie: IDE (von Tobias - 5.02.2017 18:39) | |
Als Antwort auf Re: conversie word to hex von Tobias - 5.02.2017 18:36
> > > > Frends, > > > > How can I convert cnt1 to a HEX mumber > > > > word cnt1; > > Serial_Write(0,cnt1); // send to the host > > > > Thanks. > > Dear Bram, > > what you will send to the host exactly? > In your example you will send a byte with the 'Serial_Write'-function. But then it's > unimportant if you send it in binary-format (0b....), hex-format (0x....) or decimal-format. > The result, what the Serial_Write-function send is always the same. For the different > notations note in the manual "Variablen": > > c=5; // decimal-format > a=0x3ff; // hex-format > x=0b1001; // binary-format > > > But if your host need really the HEX-format in ASCII-format, you must convert it with the > 'Str_Printf'-function in a character (%[width]x -> Hex-number) and send it then with > "Serial_WriteText"! > (http://www.c-control-pro.de/documentation/index.html?str_printf.htm) > > I hope this information helps you. Otherwise you must send more information about your > host, maybe a datasheet!? > > Regards, Tobias > Please note, that the Serial_Write-function only can send a byte, not a word! | |
