| Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt Kategorie: Programmierung C (von PepeV - 22.04.2012 16:02) | ||
| Als Antwort auf Re: Synchronisationsproblem mit Input-Capture und Timer-Overflow Interrupt von Torsten - 19.04.2012 19:25 | ||
Hi Torsten, I would not know how one could realize the solution you suggest: "der Input-Capture Interrupt den Overflow-Interrupt-Zähler umschaltet". But have you already considered another, rather pragmatic solution? One could use another timer to make a rough estimation of the period time and use that value together with the value of the Input Capture Register to calculate an accurate value of the period time. Period time measurement with prescaler PS_1 has a range of 65536 * 67.8 ns = 4.44 ms. Therefore the period time equals the value of the Input Capture Register + n * 4.44 ms. If one sets up another timer to increase a variable say every 1 ms, one could use its value in the PM IRQ function to determine the value of n. As said, a pragmatic solution, not elegant and not absolutely fail safe. Maybe you discarded it already. I think it will work in a simple program but probably not in a complex program that consumes processor time in chunks of more than 1 ms. Regards, Pepe | ||
